lowering door post
there is some adjustment in the striker, if you've loosened it up and you can't go down anymore than you need to take it off, you also need to remove the backing plate then file the squares holes down a little. You'll also need to grind a little off the bottom of the backing plate.
I have the same problem, the striker lifts the door so the top of the door is too high. Haven't gotten to it yet but its on the list of things to do before I rehang the doors.
TfcCDR
09-14-2015 12:08 PM
