Calling all carb experts, whatchya runnin!?!
So, I've got a 347 stroker. It's a Ford Racing crate engine, here's the link: http://www.fordracingparts.com/parts...tKeyField=9255. I'm in search for the perfect carb, I'm running a Edelbrock 1806 right now and I'm having nothing but problems. I'd like to run a Holley 650 double pumper, but I'm thinking maybe a 600? What works for you guys??
Thanks in advance!!!
i have a 306 with a with trick flow twisted wedge heads, crane came .498/.498 at 230 duration, edelbrock performer rpm intake, and a full MSD setup(coil distrib box) and i just purchased a 650 double pumper because the 600 single pump i had wasnt enough. my mechanic actually told me to either go with a 650 double, so im guessing with that, you should be running at least a 650 double.
if it says that it was dynoed with a 650 it would have to be a double pump because with a stroker motor ur going to have a high flow setup, and a 650 single pump i dont think would be enough at all... hope everything works out for u
I just made a trade for a Holley 3310-3, 750 with vacuum secondarys. I know it's not the ideal carb, but I traded for some old wheels I'll never use. I wonder, has anyone ran this carb? How'd it do?? I have to rebuild this one, but I'm hoping it brings some life to my engine...
I have one of those (tweaked a little from Holley specs) on my 347.
World heads, b cam, performer rpm manifold, headers, etc.... Great street carb. get the tuning kit for it and convert it to a secondary metering block instead of the non adjustable plate.
Double pumpers (when tuned correctly) will out perform a Vac secondary carb all day every day, but for street manners you can't beat a vac secondary carb. I have a 750 DP for the track(s)..... when I get back from overseas you will see my mustang on the New Jersey Motorsports track.....
do yourself a favor and just call Patrick or fill in his tech form and he will build a carb to your program .... that is what i did with my 514 ... he built me a 1005cfm carb it was right on out of box i didn't even have to tune it they are all bench tuned before sent out
http://www.prosystemsracing.com/index1.html
I run a 670 Street Avenger on my 302 equiped with the Edlebrock RPM heads cam and intake. It might be a bit much. I jetted down the primaries from 68 to 65 and upped the secondaries from 65 to 70.
James
James
