how much is this actually worth?
Old 07-18-2014, 11:03 AM
desser76
desser76's Avatar
Default how much is this actually worth?
http://rockford.craigslist.org/cto/4535672458.html
just wondering what this car is worth as i plan on picking it up soon.
desser76 is offline
Old 07-19-2014, 12:18 AM
boogerschnot
boogerschnot's Avatar
I would say between 4-7k Depending on if you find rust and how well the engine runs. And of course..... How much you really want it.
boogerschnot is offline
Old 07-19-2014, 12:25 AM
boogerschnot
FYI.. The rear end looks like it has lots of bondo in it. All of the trim has been shaved on the rear and the fender emblems. It should have a moulding and mustang lettering that goes accross the trunk lip. The carpet is not new. check that if you pour water down the cowl you dont get any in the interior. Or crawl under the dash and look as far up as you can to see rust or light coming through. Also, you will most likely need to do suspension work, springs, shocks, bushings or A arms. This car should have just about all of those things done already for 10k.
Old 07-19-2014, 12:49 AM
barnett468
barnett468's Avatar
hello;
looks like the rear quarters might have been replaced. look for orig spot welds. look underneath at the floors. stick a magnet around the rear wheel and lower quarter and lower edge of the door.
if it is straight will all orig rust free sheet metal and does not overheat or smoke and looks and runs good. its worth 9k where i live. the 3 speed hurts it.
if the clutch chatters it is 500.00. it can not be adjuste.
downshift into first at around 10 mph. if it grinds the synchros are bad. 700.00.
if the dash pad is cracked they are 400.00. make sure it does not have a plastic dash cover.
make sure the heater works and the dash vents ALL work. big big big bucks to fix
barnett468 is offline
Old 07-19-2014, 11:47 AM
desser76
desser76's Avatar
ok thnaks for all the info!
desser76 is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
2015Ecoboost
09-17-2015 01:48 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Quick Reply: how much is this actually worth?
