66 heater question
Old 08-16-2014, 08:04 AM
koda2012
koda2012's Avatar
Default 66 heater question
I can turn on my fan and hear it run but no forced air is coming thru the vents. Can feel the heat just no heat is blowing.
koda2012 is offline
Old 08-16-2014, 08:30 AM
CarGuyZM10
CarGuyZM10's Avatar
Are you using the controls right? If I remember correctly, push the temperature control (the middle one) all the way down. This changes the setting from the vents (the air boxes under the dash getting outside air) to getting heat.
CarGuyZM10 is offline
Old 08-16-2014, 09:08 AM
koda2012
koda2012's Avatar
No I haven't, but I will give a try thank you.
koda2012 is offline
Old 08-17-2014, 09:22 PM
cashs mom
cashs mom's Avatar
The heat and defroster controls on the 66 are a little wonky. The heater is the lever on the left, the defroster is the lever on the right and the center controls temp. The slide at the top controls the fan speed as I remember.
cashs mom is offline
Old 08-18-2014, 09:05 AM
CarGuyZM10
CarGuyZM10's Avatar
Yes, they are a bit odd. It's even worse on the 65, since they switched the fan speed switch mid-year. One of our cars goes Low Off High, and the other is Off Low High.
Old 08-18-2014, 10:18 AM
koda2012
koda2012's Avatar
It's not the controls. Seems like they are working like they are supposed to. Guess my next step is to replace the fan motor.
koda2012 is offline
Old 08-19-2014, 08:12 AM
cashs mom
cashs mom's Avatar
Wow, I didn't know that. The 65 my husband had was the same as both of my 66's.
Old 08-20-2014, 09:09 AM
bop11
bop11's Avatar
Are you sure you have the polarity of the wires correct. If you run the fan backwards, you get NaDa.
bop11 is offline
Old 08-20-2014, 01:04 PM
CarGuyZM10
CarGuyZM10's Avatar
Then it was a later 65, or the switch was replaced. Not a big deal either way.
Old 08-21-2014, 03:44 AM
koda2012
koda2012's Avatar
Haven't checked the polarity. I will try that thanks.
koda2012 is offline
mrtrodonet
09-19-2020 03:12 PM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: 66 heater question
