Park Lamps on all the time
Old 08-16-2014, 12:21 AM
LaBelle
LaBelle's Avatar
Default Park Lamps on all the time
My park lamps are on when the light switch is off, key off, and they only go out when I put the key into acc position.
Any Ideas?
70 Mach 1
351w c4
LaBelle is offline
Old 08-16-2014, 11:10 AM
boogerschnot
boogerschnot's Avatar
Sounds like someone wired them to the ignition accessory circuit instead of the battery power through the light switch. Previous owner maybe?
boogerschnot is offline
Old 08-18-2014, 08:11 AM
bop11
bop11's Avatar
boogerschnot is probably correct because the person wanted daylight running lights. With the proper mufflers, your 'stang should be noticed without these lights. The wire, black and yellow, belongs on the "P" terminal (center rear) of the headlight switch.
bop11 is offline
Old 10-21-2014, 08:13 PM
LaBelle
LaBelle's Avatar
Actually,, it turned out to be the alarm system. I pulled the fuse out of it and lamps are normal now. I tried a new harness in the steering column but that didn't help and created another problem. Now my horn honks when I turn the steering wheel for a sharp turn, or parking.
LaBelle is offline
carid
07-08-2016 09:55 AM
mungodrums
10-07-2015 04:01 AM
StalkerGT
09-25-2015 02:41 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Park Lamps on all the time
