finally got a classic mustang...frame rail questions
Well guys,
After looking for a couple of months I'm finally in the process of purchasing a 65 Mustang coupe, 289, 3spd. I got it for a little over $2k, but it does have its fair share of problems.
Both the front/rear passenger frame rails are rusted severly. The drivers side front frame rail has about a 1" hole in it, but is solid other than that. The driver's side rear has a lot of surface rust, but appears solid.
How difficult is it to repair the frame rails? What if there is nothing sturdy enough on the passengers side to attach a replacement peice to? Does anyone make a complete front/rear frame rail to replace the rusted out ones?
The driver's side trunk pan is also rusted a bit?
Also, the seller said that the engine has a little smoke coming from the passenger side. He said he thought it was either a bad valve or head gasket. Is there anything else that this could be?
How much do you think it will cost to repair the three frame rails: pass front/rear and drivers front?
Thanks,
Kris
Thanks,
Kris
RE: finally got a classic mustang...frame rail questions
If the frame rails are bad you are in SERIOUS trouble!!!! I mean SERIOUS trouble!!1 I had a fast back I bought a year ago that had bad frame rails in it, and BOY I got BURNT!! it was unrestorable!!!! I had to let the thing go for penny's.....Pleas tell us you did not buy this thing already...please tell us this..
ORIGINAL: wil33562
Is it possible to totally replace the rails? What all is involved in the process if it is possible?
About how much would it cost?
