Power brake mod?
Power brake mod?
I own a 66 with manual disk brakes in the front. I was wondering could i take a power booster off another car and make it work in my stang with little modification or what kind of mod would i need to do. I'm thinking of doing this to save $$$ maybe find somthing that would work at a slavage yard cheap.
RE: Power brake mod?
you could probably get a junkyard booster to work, I think some of the Mustang parts are interchangeable with Falcon and Fairlane, you may be able to find one at a salvage yard. You may have to change your brake pedal, although I am not 100% certain of this.
I converted my 66 from manual drums to power front discs. I used a booster and master cylinder from an 86 mustang. There were fabrication issues. If i rememeber correctly i cut a plate to allow the booster/mc assembly to sit more horizontally. The trickiest part was the push rod from the brake pedal to the booster were different. I cut them both off and did a little transplanting using some threaded rod for some adjustability. It sure was worth it, the power discs are 10 times better than the manual drums.
Darrin
Darrin
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
musnicki
09-23-2015 07:11 AM
cardsrus1
19
09-15-2015 08:37 AM
