Floor Pans
Floor Pans
So I got a nice sized rust hole on the driver side, and a couple smaller holes behind the passenger seat. So now Im wondering how exactly these are attached to the car? It looks like the sides have lips that are welded to the car. So If I was to buy a new one I just break those welds, drop the new one in and re weld? Somehow this doesn't seem right... Were gonna just strip the car down to bare metal since it has to be replaced and look for any other cancer spots.
RE: Floor Pans
I agree with soaring on the mig welder, it is a must. If you dont want to spend the dough on a new plasma cutter, you can rent one, or cut-off wheels on a grinder will do the job, only not as pretty. Plasma cutters take some practice and a steady hand also. You should replace both full length floor pans and seat risers. Make sure the car is level and on jackstands where it will not be moved during the process. It is not too hard of a job and the practice you get from the floor pans will help you when you go to replace the lower cowl panels, which are likely bad also.
RE: Floor Pans
Ok so it is pretty straight forward to replace? I dont think we'll be able to get the plasma cutter but we'll see how things go. Right now Im doubleshifting at work to get more money to get it replaced. Ill post pictures of the damage later on when my sister gets home with her camera. The seat platforms look to be in excellent shape. We were thinking we could get a spot weld remover and take those out saving me about $60-70 on those.
RE: Floor Pans
Yeah, I want a one piece. This is a serious drag cause I wanted to save up for the paint job and I also plan on building a new computer later this year.....but the Mustang is more important right now..
