redline
redline
So I bought a tack for my car. (66) But not for show. It has a adjustable redline marker but I don’t know at what RPM it should be redlining at red line. Any ideas? And if someone knows can they explain the concept to me? or explain it to everybody if you answer on here. I think this might be a question that people think about but never ask because so far everyone I’ve asked has little or no idea.
If it helps. It is a 289, 2brl (changing to 4 brl)
It does have a performance cam so I don’t know if that is an issue.
Thanks for any help.
Javier
[IMG]local://upfiles/49906/D7B0360109664FC6AA379E8921FFC42C.jpg[/IMG]
Javier
RE: redline
5000 is a good rev limit. yes the engine can go higher, but with a 2 barrel it wont rev that high easily. if you change the cam, valve springs, locks and retainers, add the 4 barrel intake, then you can spin it as high as 6000 easily and not worry about it.
stick with 5k and life will be good, and you wont have rods hanging out the side of your block.
nice ride.. red is always fun. I get alot of tickets in my red cars though..
RE: redline
Edelbrock RPM Air Gap manif. and Holley Street Avenger carb FTW!!!
As for the tach redline, I have my shift light set to come on at 5200, anything above 6 for me will start floating the valves.
I like Thumpin's suggestion
I like Thumpin's idea.
The tach will lag slightly behind the revs. In the heat of battle it's hard to focus on that little pointer. It's very common not to shift until the needle hits the other side, almost like an after thought.
So on a 2V car 5K is a great shift point (IMO).
JoshyGT
09-19-2017 08:52 PM
imported_admin
12
12-16-2004 07:43 AM
dhood
03-16-2004 05:20 PM
