i6 vs 289 or 302
RE: i6 vs 289 or 302
i would stick with the I6 and stay active on fordsix.com and swapping a 250 in would be a pain cause it is a taller motor than the 200 so u will have hood clearance issues
and u can get the speed and the growl from an I6 trust me i know
I am assuming that a 300 i6 would have hood clearence issues as well.
Would it be cheaper to have my engine rebuilt or buy a rebuilt engine. How much is the average cost to rebuild this kind of engine?
You could get a kit for under $500 and do it yourself. After you get the valves ground and hot tanked the block, you will most likely have around a grand in the engine. Now, that is assuming you are not adding performance parts, but are just rebuilding a stock engine. Having someone do all the work for you will cost you around $1500.
I got a rebuilt enging for $1500...you should check out www.fordsix.com if your planning on sticking with a I6...if not just buy a mustang with a V8 already in it
ya either sell it and get a v8 or just work on makin it a peppy i6. speaking of turbo'd '66's
http://videos.streetfire.net/search/...9950584517.htm
heheh.....
heheh.....
I was reading about the new FSPP Aluminum Head http://www.classicinlines.com/fspphead.asp?cat=64 and it is pretty impressive, kinda makes one rethink the idea of an i6 being a sleeper of an engine. They seem to be pretty close to completion and are claiming to be able to get 300hp with the head. I think it is expected to be released either this month or next month, my guess is that it will be a little longer than that.
I'm all for having a 300hp engine that gets 23+mpg.
im almost positive u wont still be getting 23mpg with that horsepower even with the I6 cause i have alot of upgrades on mine and im getting like 11mpg but i also drive with a heavy foot but if i drove with a lighter foot i could prolly get near 15mpg
