who sells brake lines for a dual master cylinder conversion?
RE: who sells brake lines for a dual master cylinder conversion?
Hi Walt,
I picked up a set of adapter lines from Mustang Depot. The lines were too short to make an anti-vibration loop, but they came with all the right fittings. So I went to Napa and picked up a couple of pieces of 3/16" line and made my own flares and bends.
HTH,
[IMG]local://upfiles/16598/0AEDDDA96B524153BC4819457BC8980E.jpg[/IMG]
HTH,
I got a distribution block and the 2 lines from the master cylinder from an 86 5.0 mustang out of the junk yard when I did my disk brake conversion and they worked perfect. I don’t remember the years but when they changed the master cylinder from the steel reservoir to the plastic one they changed the distribution block but the lines might still work. Its budget and works perfect.
It allows for movement between the master cylinder and the "T" block/proportioning valve. Also vibration is absorbed in the loop. It keeps the lines from splitting at the fitting. At a minimum you really want at least one loop per each stub line. The key is to make sure the line is not held completely rigid.
Galactic
04-29-2019 02:56 PM
