A New Poll!
Old 12-07-2006, 05:09 PM
grruminator78
grruminator78's Avatar
Default RE: A New Poll!
from what I understand if it's steel reinforced all you need is the light tension springs, but if it's just fiberglass most manufacturers recommend prop-rods and pins
grruminator78 is offline
Old 12-07-2006, 05:14 PM
eZ
eZ's Avatar
here is where it bolts on
[IMG]local://upfiles/18218/D586688780B541B3BEF06DD699CC1E1B.jpg[/IMG]
[IMG]local://upfiles/18218/735509B180A844C9B9FA42BF21CF239D.jpg[/IMG]
eZ is offline
Old 12-07-2006, 05:16 PM
Grimm
Grimm's Avatar
So are you using lighter springs or factory?
Grimm is offline
Old 12-07-2006, 05:25 PM
dodgestang
dodgestang's Avatar
This is a question best answer through experience and with pictures.
I have a fiberglass hood with a metal frame.
I chose to use the light weight springs.
When it was brand new, it fit perfect, now that it has been on the car for about a year,
even with the lightweight springs it has started to cause a slight bow in the hood, I have been considering adding the prop rod over the winter before it gets too bad.
New New:
Newly painted
4 months after Painted and with some minor adjustments from taking it on and off for a motor swap
11 months or so after painted (sorry for the large size so I linked it instead of imbedding it)
http://www.dodgestang.com/newmustangimages/img0266.jpg
dodgestang is offline
Old 12-07-2006, 05:28 PM
Grimm
Grimm's Avatar
I think I'll just stick with the factory hood.
Thanks.
Grimm is offline
Old 12-07-2006, 05:31 PM
dodgestang
dodgestang's Avatar
ORIGINAL: Grimm
Thanks.
Hey I loved my factory hood...so much so its still in my garage...I can put it back on anytime...its just that new intake combo I wanted to run needed another 2.5 inches
Old 12-07-2006, 05:35 PM
grruminator78
looks like I'll just get the prop rod and pins or spring 700 bucks for these http://www.mustangsplus.com/Merchant...Code=new_items
Old 12-07-2006, 05:41 PM
eZ
eZ's Avatar
man use the stock ones just take the spring out and use a hood prop. im sure you can find a way to make the prop kinda stealthy. 700 seems like a lot of money to spind on hinges that are not needed
eZ is offline
Old 12-07-2006, 05:44 PM
grruminator78
but they're hydrolic an COOOOOOL
Old 12-07-2006, 05:49 PM
eZ
eZ's Avatar
just like your landau top and wally world system...i laugh everytime i read your sig
eZ is offline
Quick Reply: A New Poll!
