R+P Shaft Shorten
R+P Shaft Shorten
Howdy- Does anyone know if you can shorten the splined input shaft of a manual rack and pinion? Id like to cut a small section out of the center and re-weld it on, so the splines are still good. I need to move the U joints further apart. Is it a hardened steel? Can it be welded safely? Thanks for any information all!
RE: R+P Shaft Shorten
i know when you install it with knew shafts i think you have to machine the steering shaft to correct length.maybe that's what you have to do. check woth the site and call them before cutting.
ORIGINAL: BlackFlame
Did you really mean R&P, or just manual?
I should have specified--nothing on the car is stock--its an 85 for escort manual rack and pinion on a custom handmade mount. The lower universal joint is interfering with my exhaust install, so, I need to relocate it--it really should be closer to the R+P, for which I would like to shorten the splined shaft of the R+P--
bradleyb
11-27-2015 07:50 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
