Carb Questions
Carb Questions
Okay, I'm still messing with my carb...
I recently rebuilt my ford 2 barrel carb. (Thanks to everyone that helped me with that.)
This afternoon I noticed that there is still fuel leaking on the manifold. It looks as though its coming from the idle mixture screws. Is this possible? Is there supposed to be some sort of "O" ring to keep it from leaking...or maybe my threads are not tight enough? Any advice would be greatly appreciated.
Also, while *attempting* to adjust the idle mixture screws, there was no discernable difference between the 1.5 turns out that I started with and a fully seated (all the way in) comparison. I would have guessed this would have stalled the engine or at least made it idle roughly. Nope, it just idled away. (However, I did not try both sides in at the same time.) Also, I didn't see any fuel pouring over (i.e. a stuck float), but I certainly couldn't figure out how it was still running.
Since I'm out of daylight I thought I'd pick your brains. What am I missing?!?
Thanks as usual.
Thanks as usual.
RE: Carb Questions
The left screw makes a difference at idle, right? The right one is for higher speeds. Just turn it out about 2 1/2 turns.
Adjust the left one where the engine idles smoothly. No, this is not the scientific approach, it's just what works for me with my Autolite/motorcraft 2V on my 289.
RE: Carb Questions
If I remember correctly there should be a cork gasket around the needles too, usually they stay in the carb housing/baseplate and people dont notice them.. Look in your kit and see if there are a few very small round pieces of cork in there.
RE: Carb Questions
The small cork gasket is on Holley carburetors, not Ford/Autolite/Motorcraft carbs. If it is a pre-emission model, then the idle screws should be roughly 1 1/2 turns from seated. If it is an emission model, 1968 up or a service carb (will usually have a number like D2PF, C8PF on it) then the screws will be 2 1/2 - 3 turns out. You can tell the difference if you look at the mixture screws. Early carbs (up through 67 US, 65 or 66 California) will have fairly stubby points, later ones are longer. If you are leaking fuel, check the accelerator pump cover, make sure it is flat and tight, they are very prone to leaking there as they get older. One item, if you have an emission carb, the idle screws are mixture trim, and will not have as much effect as ealier models.
RE: Carb Questions
I have a holley 4 barrel 600 CFM JUST rebuilt, profesionally, taken down to bare, rezinc( looks chrome) coated, new gaskets and everything is new. I put it on and cant get it to run right( less than 30 mins run time)... dont like the idea of tuning this particular one( holleys are a pain i hear- so thats steering me to edelbrock) and... i dont want an electric choke. want to buy it? 200$ shipped. And ill get something else! -Jon
RE: Carb Questions
ORIGINAL: crunchyskippy
