rear leaf springs
Old 09-16-2004, 03:20 PM
gizahuna
gizahuna's Avatar
Default rear leaf springs
I have a 68 coupe and I am replacing the rear leaf springs. I got the ubolts and rear bolts out without a problem but the front bolt is not moving. Is there a trick? Am I missing something? Any suggestions?
gizahuna is offline
Old 09-16-2004, 08:42 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: rear leaf springs
soak them in penatrating oil overnite and get a impact
vfast is offline
Old 09-17-2004, 09:34 AM
horseshoeing
horseshoeing's Avatar
If that don't work you can heat them up and let cool then try. If that don't work get a cheater bar about 6 feet long. If that don't work you can cut it off with a nut cutter.
horseshoeing is offline
Gene K
10-21-2015 11:37 PM
09-16-2015 07:53 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
Quick Reply: rear leaf springs
