Backfiring
Backfiring
I just finished a rebuild on my 289 and put it back in the car. I'm trying to crank it and it's backfiring and spitting fire out the carb. True, it's really colorful to watch at night, but I'd rather drive it. Anyway, I've checked and rechecked my plug wires to make sure they're not crossed and they look good. I've pulled the #1 plug out, and pulled the distributor off and, while having someone turn over the engine, put my finger over the spark plug hole and watched where the rotor was positioned when the compression pushes my finger off the hole... and it looks to be at the #1 post when it compresses.
I've got a couple of ideas at the moment... one, I replaced my distributor cap with an Accel Super Stock one during the rebuild and it fits pretty sloppy. I'm going to stop by the autoparts store this evening and get just a stock cap/button and see if that's the problem.
Two, I'm wondering if I have my timing chain 180 degrees off, will the #1 compression still match up with the #1 firing time, but some of the other cylinderswon't? I'm going to try and test out a couple more cylinders this evening to see if that's the case.
Three, I figure it's a slim chance, but I changed the stock cam out with a Edelbrock Performer RPM cam during the rebuild and wondering if I might have the wrong cam in. Dang, I hope not.
Anyway, if anyone has any suggestions on some other ways to figure out what's causing all the fireworks, I'd sure appreciate some ideas.
Thanks.
Thanks.
RE: Backfiring
1:00 O'Clock when the compression blows my finger off the hole.
For the other replys, Ithought on the exhaust stroke, the exhaust valve should be open and so, there'd be no pressure blowing through the spark plug hole at that point.
...and thanks for the replys!!
RE: Backfiring
If you are absolutely positive you have static timed it correctly, then let's go back and double check the firing order.
15426378
4 8
3 7
2 6
1 5
Front
If that checks out, then go back and double check the procedures you used to install the timing chain. It may have slipped a cog.
15426378
4 8
3 7
2 6
1 5
Front
RE: Backfiring
its worth double checking the cam's firing order. some aftermarket cams use the 351w / later 302 firing order(1-3-7-2-6-5-4-8) , which is actually supposed to be better.
but +1 on the dizzy, thats always first culprit
RE: Backfiring
ORIGINAL: my77stang
RE: Backfiring
With theno. 1pistonvalve cover off, use the started to rotate the engine. after the intake valve goes down and back up check the timming mark on the damper. when it is at zero. The roter should be pointing at the Number one spark plug wire. If it's not move the distributer until it does. then wire the fireing order. for a 289 cam. If it still miss fires check the cam, 351 windsor had diferent fireing order like someone said. Don't back fire the engine, this may bend rods or valves.
RE: Backfiring
what kinda carb you running on there? a single backfire can wipe out the power valve on an older holley (cheaply replaced) - the newer ones have blowout protection though
damn, they know my name *Shane ducks and runs*
Very valid point Shane
