Stubborn axle seals
Stubborn axle seals
I'm in the process of replacing the original axle seals and I have tried everything to get them out. I've been working on the drivers side for about an hour and it isnt even close to coming out. Give me some tips on what I can do! Thanks.
Before
Now
Before
Now
RE: Stubborn axle seals
Glade you got it out. To answer your other question, No it wont hurt the place that you would have pried. That area is hardened, the seal gives instead of the screwdriver nicking the serface, Done it about 50 times with no problem.
Next time you try this , use a claw hamer, put the claws under the seal and pull the nail, works just like a seal puller except its free.
I was going to replace the bearings. I took the axles to a shop today and he said my bearings are still good. So I'll just replace them some other time.
bradleyb
11-27-2015 07:50 PM
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
