i think its time to rebuild the motor!!
Like i said before, when starting the car i get a cloud of white smoke and then it clears away, but then after 5 min. of warming up, when i rev pretty high i get some more white smoke! what does this mean? is it time for a rebuild?
RE: i think its time to rebuild the motor!!
ORIGINAL: rmodel65
is it running hot? blue smoke means ur burning oil, white(steam water) greyishh white to black running to rich
bypass the heater to stop the leak and see if its still running hot after toppin off the coolant system als go to autozone and get the coolant pressurizer(its a loan a tool) to pressurize the system to make sure u dont have a blown headgasket
it should hold pressure without dropping drastically
what is the temp where ur at?
i means is it cold out side? it can make it look like its smoking when its not really. know what i mean?
but yes definitely check the coolant system with the pressure tester then go from there
ORIGINAL: my77stang
who cares what the problem is, smoking justifies a rebuild and go-fast parts!!!!!!!
...I know theres lots of people out there who have had there engine(s) rebuilt. I know there LOTS of steps during this process, but what are the main steps i need to do for a rebuild. during the rebuild i also want to add a few "go-fast parts". i want a (street/strip) at least 325hp!! Saying that, what parts and things do i need to do to the motor to achieve this goal??...
