Has anyone painted their interiors themselves?
#21
RE: Has anyone painted their interiors themselves?
I'm just getting set to do mine now. Keep in mind the fine stamped texture of the inner door skins. You don't want to fill that up with primer. Remove all the paint from the door panels with paint remover.Comes off easy with Jasco paint remover. Sand very lightly after.
Instead of primer for the doors, try a light coat of clear. The final paint will stick well to that. Keep the paint thin, using a couple coats from a quality spray can. Remove all you can from the dash, steering wheel, and dash pad if possible. Tape off everything else. Take your time.
treesloth
09-28-2015 07:03 AM
