what carb is this (pics) and where are the adj. screws ?
Hi all,
i was convinced the carb looks like a autolite 2100, but there's a sticker on the side that says "holley remanufactured"
venturi seems to be 1.14
Does anyone know what carb I'm dealing with so that I can look up on how to adjust idle and mixture and fast idle ?
oh and yes I know... the way the spring is attached is kinda off. But I had to. The carb moves easy, but the pedal just a hint to stiff, so the spring wouldn't pull the pedal back. it's fine now
[IMG]local://upfiles/52145/C2241BBD69284414A07BF1E76BCE0B02.jpg[/IMG]
[IMG]local://upfiles/52145/34A55C44F29D4E459B2D4219CD55B4CB.jpg[/IMG]
[IMG]local://upfiles/52145/3CDBCA68318547E183F4B2371CE6B1FD.jpg[/IMG]
RE: what carb is this (pics) and where are the adj. screws ?
as you wish ... ;-)
[IMG]local://upfiles/52145/AA55503A27614810B0DEF8DA1A53C55E.jpg[/IMG]
[IMG]local://upfiles/52145/31CD33A2952D4126B65CD8E66F38AA19.jpg[/IMG]
[IMG]local://upfiles/52145/336B6A31E9F34A6B8B5AF6FB1D3435C3.jpg[/IMG]
[IMG]local://upfiles/52145/33EA6C362AA44C83A6A6C1657CDDDFEB.jpg[/IMG]
[IMG]local://upfiles/52145/181E5AF5663A4FD9A7592BA1633A288E.jpg[/IMG]
hm .....
according to ponycarburators it's a autolite2100, just as I guessed.
http://www.ponycarburetors.com/images/location5.jpg
wonder what that stupid holley sticker does on the carb then ....
If I'd take the pictures earlier I probably wouoldn't have had to ask ...
thanks very much !
While looking it up I read through this article:
http://www.ponycarburetors.com/defau...tail&id=36
The article mentions that it's wrong to believe that one side of carb feeds one side of engine. It's spread between inner 4 and outer 4.
And while reading this I remembered a post which I can't seem to find anymore.
His inner 4 cylinders would have a foxy brown spark plug while the outside ones were off (black/oily if I remember right).
That might be what he's having problems with ?!
Soaring: you posted the cylinder numbers for that fella.
Do you think this might be related ?
basically that just one side of the carb is running too rich or lean ?
kalli
kalli
ORIGINAL: kalli
thanks very much !
kalli
thanks very much !
kalli
I just thought he said that the most outer cykinders are running rich.
So if ponycarbs say that if you have the Ford dual intake manifold, one side would feed the inner cylinders and the other the outer cylinders.
Now if there's 2 mixture screws on the carb, maybe one screw (mixture) is feeding one side of the manifold->outer or inner cyls
So I thought maybe it's just that. one of the 2 mixture screws running too rich
Kalli
Kalli
