My buddy wants a lopey cam
so my friend at school has a mustang just like with a 289 in it and he wants to do a cam in it with a nice lope to it so he got me some part numbers and i looked them up at work and i think he might be going a little high on it i wanted to get some more oppinions
first was the clevite 229-2058 = 218int/exh @.050 with a .488int/exh lift and a 105/115 lobe center
second was the crane 130092 = 222int/exh @.050 with a .498int/exh lift and a 110 lobe seperation
third was the comp 268H = 218int/exh @.050 with a .456int/exh lift and a 110 lobe seperation
fourth was the lunati here listed as shleby cam in lunati book
fifth was a lunati here voodoo cam
sixth was the Ford Racing Cam here i recomended this one i was told it would be ok but i havent installed it yet
seventh was another clevite 229-2138 = 224int/exh @.050 with .466int/exh lift and a 106/114 lobe center
eighth was another clevite 229-1616 = 228int/exh @.050 with a .477int/exh lift and a 108/120 lobe center
i didn't quite know what one would give hime a fair idle with a good lope i am not a cam guru so i leave it to you guys
RE: My buddy wants a lopey cam
In my '65 GT I had a Comp Cams 270H which gave a nice lopey idle but was still quite streetable. 0.5" total lift, duration @ .050 = 224/224.
http://www.compcams.com/Technical/Se...umber=31-414-3
i know thats why i was against the 228 dur cam cause i know that might be a bit much cause the smaller the motor the more noticeable a cam is and the more it affects it thats why i was thinking the clevite 229-2138 = 224int/exh @.050 with .466int/exh lift and a 106/114 lobe center would be plenty
ORIGINAL: Brandontyler65
ya i mean he wants a nice lope but he don't want the car to shake to hell he don't mind a noticeable one just not rough to where its annoying sitting in traffic
Brandon, unless he has better valve springs and had checked the guide to retainer clearance i would go with either this...
comp 268H
or this
clevite 229-2138
i had a summit grind 218/228 @ .050 with .471 lift in a otherwise stock 302 with a holley 600. it didnt have too much of a lope but it pulled VERY hard from the bottom up to and past 5k rpm's
comp 268H
or this
clevite 229-2138
ok well he either wants the clevite 229-2138 or the ford racing cam or the comp 268H what one would give best performance all around
i was thinkin that the ford cam waould have some lope to it because of the longer exhaust duration and i have heard that it has a little chop to it from a member on stang net but it seems like no one else has used one and i haven't installed mine yet
