IS THIS A DUMB IDEA?!?
#21
RE: IS THIS A DUMB IDEA?!?
performance wise, it is not going to do much for you, unless your motor is built up a little to the point where it needs the extra airflow. ya ya ya, you're going to get colder, denser air, but you'll be accomplishing the same thing by just buying a K&N filter setup and get one of those Xtreme filter/lids.
#22
This is likewhat I have on my car:
K&N 14" x 3"Air Filter and Stubstack & the K&N Xtreme top. I also had to go with the HI-PO air cleaner because of hood clearance. I do have the Shelby style fiberglass hood so I do have fresh air coming through the scoop and through the Xtreme top.
Good luck.
K&N Stubstack[/align]
K&N Stubstak with the lower pan and K&N filter element.[/align]
The K&N Xtreme filter cover installed [/align]
Good luck.
#25
Got to admit, that does look pretty trick (that is, the dual cold air intake on the yellow car). I bet my monte carlo bar would interfere with those hoses though...
Adrian - thislooks like abetter and more functional idea than the cold air intake in your original post. There must be a cold air source to get your cold air, and the thing you posted doesn't seem to do the trick.
#27
There is a company in Canada that makes CAI systems for your car. Don't remember their name but the system looks like factory and has 4 in tubes that feed from the radiator support. Why not just install a 3 in cowl induction hood and seal it from under hood air. A huge advantage to this type CAI is that it is much les likely to take in water and hydraulic lock your engine.
#28
ORIGINAL: jspagna1
Good luck.
Have you ever noticed how the water just dances around the center of your hood when you drive in the rain? There is a REALLY good reason NASCAR uses a cowl induction system and that is that there is very little if any 'ram-air' affect at the center of your hood. The GT-40 and the Daytona Coupeused the low pressure area in the center of the hood to evacuate air from behind the radiator!
Good luck.
#30
[8D]I knew someone was going to think those were pictures of my car. No, my intake is NOT purple,it's aluminum.
And I don't have a problem with the rain on my hood beacuse I never drive my car in the rain. It would be especially difficult because I don't even have windshield wipers on my car.
Seriously,I'm just telling him what I run on my car. It's up to him to decide what he wants.Isn't that what these forums are for? I won't have to worry about anair cleaner at all if I Supercharge my car like I'm planning on doing in the spring!
