Flat spot from idle
Old 04-14-2007, 10:53 PM
rhinobacker
rhinobacker's Avatar
Default Flat spot from idle
Help me, I've adjusted the timing but still have a flat spot on my 68 289 from idle to about 3500rpm then it's fine.
rhinobacker is offline
Old 04-14-2007, 10:59 PM
350kmileFord
350kmileFord's Avatar
Default RE: Flat spot from idle
Sounds like my Mustang, 'cept it only lasts till about 1500 rpm.
Same issue on my '71 F-250 >_<
It goes away completely on the Mustang once it's warm though.
350kmileFord is offline
Old 04-14-2007, 11:18 PM
rhinobacker
Strangely enough after I had her running for little while yesterday it did get a bit better. Given that she is unregistered at the moment I can't rlegally take her for a big drive but I will try and leave her running for while and see what happens. Thanks.
Old 04-15-2007, 02:53 AM
alderpulp
alderpulp's Avatar
my 68 289 was the same...a friend rebuilt the 2 barrel carb for me....it got better, but didn't go away...I just put in a petronix pointless ignition, and it has GREATLY improved the flat spot......it is very very minor at this point...ap
alderpulp is offline
Old 04-15-2007, 05:12 AM
rhinobacker
Thought I better add a photo of my girl. She is in need of some TLC, but that was one of the reasons I bought her.
[IMG]local://upfiles/66019/1E3D056E4B0941A2821DD1C4CB3816BE.jpg[/IMG]
Old 04-15-2007, 05:52 AM
350kmileFord
A fellow deuce-panner >_<
Old 04-18-2007, 07:30 AM
rhinobacker
The flat spot has now moved to 1500rpms. I've put in a new coil and went to gap the points and adjust the dwell and the f0rken points and condenser looked 40 years old. I feel like an idiot. Why would someone change distributor cap, rotor, leads and plugs but not the points (the previous owner). I should have looked at these first. Hopefully this fixes everything. BTW I am working on a Dwell of 30 degrees. Does anyone disagree?
Old 04-18-2007, 12:59 PM
Soaring
I ♥ Acer
Soaring's Avatar
According to my Haynes manual, the '68 289 dwell angle is 27. Point gap is 0.021 and the initial timing is 6 degrees BTDC.
Soaring is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
popsotto
09-28-2015 06:58 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Flat spot from idle
