Rear end Swap
Rear end Swap
I have a 1966 mustang and I want to swap the 4 lug rear endin for a 5 lug rear end. What are the best bolt on donor cars.
I installed a new Holley 2300 Carb but the original throttle rod is too short. Any suggestions on where to find an extention or a longer throttle would be helpful.
Thanks
Thanks
RE: Rear end Swap
don't know about the throttle rod, but there was just a post on this the other day:
https://mustangforums.com/m_3220316/tm.htm
Lots of posts pull up on a search, too.
Good luck
Good luck
RE: Rear end Swap
Here's an article packed full of other donor cars for your rear and they are all 9 inch rears.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
RE: Rear end Swap
Here are the years/models with the same rear end size asyour car. Your best bet is finding a V8 Mustang in a wrecking yard and taking that rear end out to be overhauled.
'57-'59 FORD/EDSEL
'63-'69 FALCON
'63-'69 COMET
'63-'65 FAIRLANE
'65-'66 MUSTANG
'66-FAIRLANE/CYCLONE
'57-'59 FORD/EDSEL
'63-'69 FALCON
'63-'69 COMET
'63-'65 FAIRLANE
'65-'66 MUSTANG
RE: Rear end Swap
ORIGINAL: JamesW
'57-'59 FORD/EDSEL
'63-'69 FALCON
'63-'69 COMET
'63-'65 FAIRLANE
'65-'66 MUSTANG
'57-'59 FORD/EDSEL
'63-'69 FALCON
'63-'69 COMET
'63-'65 FAIRLANE
'65-'66 MUSTANG
RE: Rear end Swap
Sorry to hijack, a little, but Soaring, what do you mean by "If not, that 7.5 inch rear is all that 200 I6 needs."? I have a 200 - surely you don't mean I can use the stock housing, do you? Or do you mean, that 9" isn't really needed for the low powered I6? Thanks
RE: Rear end Swap
ORIGINAL: mySAVIOReigns
RE: Rear end Swap
lol, I couldn't find what you said
Wow, that opens another can of worms....Now I'm super confused - all I need is to change the axles? (+ all of the disc brake hardware stuff).
Sorry, but all of the write-ups and how-to's I've seen all went to a larger axle, which I don't need. Know of any place to look where I can keep the stock axle?
RE: Rear end Swap
with the 4 lug its a 7.5 rear end no one makes 5 lug axles for it you have to change out the rear end for a 8 inch or 9 inch .yeah if your sticking with the inline 6 a 8 inch is more then enough if you want a mean nasty v8 a 9inch is a must
RE: Rear end Swap
To answer a lot of questions. I have decided to keep the I6 200ci with some modifications to hop it up. I have converted the the front to disc brakes and I want to have a matching 5 lug rear. With what I am doing, I only need an 8 inch rear but I have no problem with a 9 inch risk. You speed demons might think this is a waste but I am a 30 something who will drive this car on Fridays and to the golf course with a cigar hanging out of my mouth. Build cars is a new hobby that I have always want to do but I couldn't afford it until now.
