Phenolic spacer (with PICS)
RE: Phenolic spacer
Just google "Phenolic" and you will get lots of hits. Just take the carburetor off and slip it on then replace the carb. Easy as pie. You will notice a tad more horsepower because the swirling effect of the gas/air mixture has a little more time before detonation. You'll also notice a cooler carb and less incidents of vapor lock.
RE: Phenolic spacer
http://store.summitracing.com/compar...=KeywordSearch
Are these what I am looking for? How to determine which to use, I dont see any indications or is it based on the carb you have?
RE: Phenolic spacer
ORIGINAL: ndnboy
RE: Phenolic spacer
I havea 289 , with a 4v Edelbrock carb.
which will be best:
EDL-8711 - phenolic- $31.95
SUM-G1405 - phenolic - $ 29.95
SUM - G1412 - platic - $13.95
All 3 call for a 4v square bore.
Is this something a local Autozone would carry or is it best to go through Summit?
which will be best:
RE: Phenolic spacer
dont forget to grab longer carb studs when purchasing a spacer
from what i gather, an open spacer is going to raise your powerband of the intake a little compared to a 4 hole spacer - it kinda acts like the plenum divider notch on the airgap intakes
RE: Phenolic spacer
OK, as you are probably aware, not all phenolic spacers are built alike. You need to get one specifically for that model of Edelbrock carb you have. Call the tech line at Edelbrock and ask them which phenolic spacer you need and where to get one specifically for your model of Edelbrock carb. 1-800-416-8628
