there must be another way
#21
RE: there must be another way
Here is a qoute I got for a 9". You may find this helpful
Nic-
Here is what we can do on a complete 9" Ford Rearend for your 67 Mustang:
$650 - 9" Housing/Axle Package (67 Mustang)
- Moser Axles, Big Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, 5 on 4-1/2" Bolt Pattern, 1/2" Studs
$820 - Center Section (Assembled)
- New 31 Spline Trac-Lock Posi
- New Motive Performance Gears (3.50)
- New Timken USA Bearings
$369 - 11" Disc Brake Kit w/ Parking Brake
TOTAL $1839 + 150s/h
This would be a complete 31 spline setup with your choice of gear ratio. We use new Moser axles (not factory re-splines). We also use new trac-lock posi units, not torque-lock units (modified open carrier).
This center section would be good up to 500HP. If you plan on having more than that you will want to go to an aftermarket setup. It would be $1125 instead of $820 for a complete center with the Strange Nodular Iron S-Case, Aluminum or Iron Daytona Pinion Support, 1350 Steel Yoke, Motive Performance Gears, 31 Spline Trac-Lock Posi, & Timken (USA) Bearings. ALL NEW & ASSEMBLED!
Let me know if you have any other questions.
Thanks,
BRYDON
641-751-8060
He had a listing on ebay which is where I originally saw it, but I believe the website is www.quickperformanceracing.com.
Nic
Nic-
Thanks,
BRYDON
641-751-8060
Nic
#22
keep in mind the torque your gonna be putting down, the hp isnt the killer of axles and drive shafts and ****, its the instant jolt of holy **** power thats putting you in the back of your seat that kills your drivetrain.
#23
ORIGINAL: Mustangdemon67
i just said i got a whole setup for 1500. you just have to look around
ORIGINAL: Mustang.
i want to spend no more than $2000 (if that's even posible). and i want it to hold 500 to 600+ hp.
#28
ORIGINAL: baddog671
Nic-
Thanks,
BRYDON
641-751-8060
Nic
Nic-
Thanks,
BRYDON
641-751-8060
Nic
