wilwood brakes
wilwood brakes
Im thinking about buying willwood front and rear disk brake kitfor my 67 from hot rods usa.I was wondering if anyone used them or heard what they are like for a daily driver or are they mainly for racing.
thanks
thanks
RE: wilwood brakes
ORIGINAL: MIKKO
thanks
thanks
We also have Willwoods on the back of my son's truck, same thing perfect in fit, finish, and function, only thing is these are a little squeaky...
So I guess we have a full set of Willwoods, they are just on two different vehicles...
RE: wilwood brakes
ORIGINAL: MIKKO
What company did you buy yours from. Im looking for a good dealer.
RE: wilwood brakes
I'm running Wilwoods on the front of my 67 that I drive every day. The quality is excellent, as well as the performance and durability. They are noisier if you use higher performance(ie higher temp) brake pads, but it's a small tradeoff for excellent braking
RE: wilwood brakes
Did you have to change the spindles. I have stock 6 cyl spindles. I was toldI had to change mine and they have 71-73 spindles.Im looking at a kit from Hot Rods USA and am not sure about the company.
RE: wilwood brakes
ORIGINAL: MIKKO
I have heard that the 71 - 73 spindles are stronger than the earlier ones, but then I have never heard tale of an early spindle breaking....
We got our stock V-8 spindles over e-bay for $200....
RE: wilwood brakes
ORIGINAL: MIKKO
Thanks for the info. I guess Im off to find some v8 spindles now. Will the v8 spindles of any year from 64 to 73 fit the rest of the steering.
I do know that your 67 steering components do not need to be upgraded to "V-8" like in previous year Mustangs, as far as the interchangeability between years, I am not sure enough to give advise.
Anyone else???
