Good Resto?
Good Resto?
i currently have a opportunity to buy a '72 mustang grande. its a bare shell im planning on sending it to be chemically dipped and cleaned. so i can do the metal work myself. what are some things to look for in doing this. and what parts should be solid if considering a good resto car. i have posted some pics
[IMG]local://upfiles/42795/2F2F77E9C5CD4EAF83D1FEB0CBCF33DC.jpg[/IMG]
[IMG]local://upfiles/42795/9ADAA434A8F642F583FAB78B399917CA.jpg[/IMG]
[IMG]local://upfiles/42795/20080C1119CB48129DC698265AEB25EE.jpg[/IMG]
[IMG]local://upfiles/42795/DE4985DD4F97441393ABC56962F86F8D.jpg[/IMG]
[IMG]local://upfiles/42795/E0B3550FB1F24569B6297002EA41B6E8.jpg[/IMG]
RE: Good Resto?
no dents really from what i can see atm but i mean how much rust is too much rust. whats my best bet to getting the body the cleanest? chemical or media blasting? and where can i locate a cowl replacement panel for this year?
RE: Good Resto?
if u have the money id do both acid bath first then blasting but if u can only do one id go with blasting just because it will blast of little chunks of rust so you can really tell how deep your in, for the cowl id check here http://www.mustangdepot.com/OnLineCa...department.htm
RE: Good Resto?
the acid works good and gets rid of a lot of paint and rust, but the the sand blasting will get rid of every little rust spots so you can little pin holes in your floor bords if you had any rust at all, but acid is fine but if your a perfectionist then id go with both.
RE: Good Resto?
both have there pros and cons from pricey to i heard the acid will weaken the metal not sure if its true tho.media blasting is cheaper i had my 68 one with crushed wall nut shells there was a couple spots i had to dolly and hammer smooth but those where in the firewall ford left a wrinkle in my firewall.
RE: Good Resto?
I hope that when you're buying that car in the photos...it comes with several boxes of parts. The problem with 71-73s is that all the little brackets and frackets are not reproduced as much or as cheaply as the 65-68 parts. You may find that the rust work is the cheap part...
RE: Good Resto?
i have the basics to put the car together as in doors hinges etc i plan on doing a restomod im not restoring it to original more or less turning it into a monster.
mungodrums
10-07-2015 04:01 AM
