Too much....
#32
RE: Too much....
I think my holley 770 carb is just too much for the 390bb.
Using the formula at Pony Carburetors for calculating CFM, a 770 carb is big unless you're pulling close to 7,000rpm.
390/2 x 6823/1728 = 770cfm
A "stock" 390 has a max rpm of 5,556 based on piston speed.
390/2 x 5556/1728 = 627cfm
Too big of a carb causes the speed of the air going in to slow down which will cause improper fuel atomization. An idle or off idle stumble will result.
A good tune up will mask the problem and the car's going to run, but if you're not looking at 7,000 rpms I would think a smaller (650cfm) carburetor would give you much better response.
That's my view from this side of the street, but I'm old enough to know there's a big difference between numbers and the real world.
I hope the tune up leaves you smiling.
#34
RE: Too much....
I don't know if this has been said before but check your vacuum lines. A small vacuum leak can turn into a big problem. The hard shifting could be vacuum related as well, or it needs a rebuilt (mine was the latter ). My 351 had a leak at the carburator which in turned made it hard to tune, so make sure all the vacuum lines and the gasket at the carb all check out.
One trick a tune up shop taught me was to use two carb gaskets to ensure a good seel, they are kinda thin and sometimes an edge might be off so they use two to get a good seel there.
Ever try driving around in first gear during traffic then shifting when you tell it to? Thats what I would do with my auto if i had this problem.
mustang99v6
V6 General Discussion
30
08-06-2011 11:02 PM
