Painting a 1966 grill
The grill has 3 edges/sides to it-front,back and in between......I know the front stays chrome,and the back is sprayed black...when you spray the back does the "in between part" get sprayed or stays chrome...
the bracket holding the pony on goes black and argent inside the pony corralcorrect?
just a little confused on how much of the back is black thanks scott
RE: Painting a 1966 grill
ORIGINAL: sixtysix
The thin front edges of each grill fin are silver, polished aluminum I believe. the fins themselves are satin black.
The surround has a chrome outer lip, and the inner recessed part of the surround is silver paint.
When I painted mine recently....I painted the front and in between withsemi-gloss black. I then used a razor to remove the new paint from the front edges.I didn't think that I would be able to mask thefront edges since they are so small.
thanks for the input-so it sounds likeI can paint the whole grill black and then just lightly sand the front edge back to the silver aluminum.
I will mask the top and bottom edges of the grill too.
pony corral will be painted argent on the inside
chrome trim recessed area painted argent in the middle area.
thanks Scott
thanks Scott
Why must you mask the top and bottom edge? Except for the front edges the whole grille is semi gloss black.
Hold the presses.
I just noticed your car is a GT. There's a lot of debate about GT grilles. Some people say they're the same as a regular Mustang and have the silver front edges. Sone people say the whole grille was black, even the edges. When I was a boy I remember seeing more than one GT with an all black grille. Now whether the owners or the factory painted them I don't know. But I know I saw them, and they were new cars at the time, so my GT has an all black grille.
