Motor Question
Motor Question
Guys,
This is where I need the most guidance.
If you look at my other post you can see pics of the pistons and heads. https://mustangforums.com/m_4028621/tm.htm
I am planning on rebuilding the engine and would like to make around 300 hp.
I have the opportunity to buy a dissasembled roller short block for around $75. The owner says it needs a rebuild and that the number 8 piston has a cracked skirt. Would it be worth buying the roller block and rebuilding that for my mustang? I am trying to keep the budget as low as possible but want decent power.
Even though they are not forged, if my 302 non-roller pistons are in good shape, could I use those in the roller motor? I'm planning on using my 289 heads and getting a mild port and polish, or at least a valve job. (You look at the pics in the above post and tell me what I need)
I consider myself competent when it comes to engines, but I have never had one rebuilt or built one myself.
Thanks,
Parker
Thanks,
Parker
RE: Motor Question
i dont like the idea of anything cracked internally on a motor, it means something is now weak and will break easier down the road. i would personally go to a junkyard and buy the complete engine and rebuild from their, its safer that way, and now you have all the pieces as well.its hard to beat a complete engine for 300-400 bucks. and then you can rebuild it put a stronger cam 4bbl holley 600cfm and better flowing head or port the ones you got sell the origional pistons and put that money toward aftermarket high comp pistons and that should get you close to you 300 hp goal.
RE: Motor Question
ORIGINAL: boogerschnot
Wouldnt you replace the pistons in a rebuild anyway... I would go for it and build a mean roller motor..
RE: Motor Question
Could I make 300hp on a flat tappet motor with an upgraded cam and a mild port and polish on the heads.
If this rebuild stuff starts getting too expensive I'll just have to wait a year and buy the 347 stroker from t and l.
RE: Motor Question
ORIGINAL: PReal
RE: Motor Question
I already have a performer rpm intake maniforld, hedman long tube headers, and a holly 600 cfm vac secondaries carb.
I was planning on just getting the block tanked and inspected, and rebuilding it.
