Windsor or Cleveland
RE: Windsor or Cleveland
Eh, performancecleve builds can cost more. Parts, while more available now than 5 years ago, are still not anywhere near as common as windsor parts. Also harder to find a machinist familiar with cleves.
ORIGINAL: RSRXION
NEITHER ! Or both depending on how you look at it. I'd say build a Clevor. It's easy and they've been doing it for nearly 40 years. The secret code for it at Ford ? Boss 302
If you are going to build a cleveland this forum is a good rescource.
http://www.network54.com/Forum/119419/
ORIGINAL: pushrodpower
There is no benefit to building a clevor unless you want to use an aftermarket block. Stock to stock one block is as strong as the other.Also your intake manifold selection is severly limited and expensive. Your best bet is to either build a cleveland or a windsor.
ORIGINAL: RSRXION
I've run them in a dirt modified and you'll just have to believe me when I say they are torque monsters.
JMHO, Dean
ok are you looking for an almost stock setup or what?
my suggestion is get the windsor block and use clevor heads windsor head choke your motor more than the clevor heads. and you save from aftermarket until you can build up fund for really building a motor.
