9" rear from a '66 Galaxy?
RE: 9" rear from a '66 Galaxy?
A stock 68 differential is 59.25" from axle plate to axle plate, so at 61 inches it would extend less than an inch wider on each side. The stock spring perch span is 43 inches.
ORIGINAL: 69FECoupe
FWIW - a 66 Galaxie has a coil spring rear, not a leaf type. If it is the right width, you'll need to remove all of the coil spring stuff and install leaf mounts.
