carbon buildup and cleaning
Old 11-12-2007, 06:51 AM
loose_nut
loose_nut's Avatar
Default RE: carbon buildup and cleaning
No you cant- you can get seafoam form pepboys or whatever, but the CCC is way better- well worth the 30 minute drive.
loose_nut is offline
Old 11-12-2007, 07:12 AM
JERM_1967stang
JERM_1967stang's Avatar
ok ill make that trip some time this weekend and ill letu kno how it worked
JERM_1967stang is offline
Old 11-13-2007, 04:16 PM
scouttrooper
scouttrooper's Avatar
I could not believe my eyes the first time I saw this, but I've since seen it work very effectively multiple times without adverse effects. An old timer showed me this. Crank up the engine and let it smooth out a little. Expose the carb and manually open her up to 3000-3500 and slowly pour about a quart of cool water into the carb- while it's running- and it will waste a goodly amount of the carbon gunking up the works. It'll sound like it's under water when you do this. I agree with others that carbon is likely not causing your smoking, but it certainly can reduce your airflow. I've not seen a negative result yet.
scouttrooper is offline
4cylinderplus2
10-09-2020 07:45 PM
svfetter
10-05-2015 11:39 AM
Dathan
10-05-2015 05:52 AM
mdg
10-01-2015 07:04 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: carbon buildup and cleaning
