official build up 289
Old 11-13-2007, 06:12 PM
Deviousfred
Deviousfred's Avatar
Default RE: official build up 289
I don;t have a lot of experience with tri-y headers but it would seem to me you would benefit more from long tubes with minimum 1 5/8" primary tubes if you're hoping to reach those hp numbers.
Deviousfred is offline
Old 11-13-2007, 06:39 PM
SalikDDD
SalikDDD's Avatar
tri's are already here - i didn't want longtubes due to moving crap around and all that jazz. technically the tri is a long..
SalikDDD is offline
Old 11-13-2007, 07:31 PM
my77stang
my77stang's Avatar
use the 289 rotating assembly in the 302 block, thats the best combination as the cylinder walls go down a little further in a 302 than in the 289's which equals better piston stability. plus, the 302's are a dime a dozen.
also, PLEASE upgrade your rods bolts. i cannot stress how important it is to recondition your rods and upgrade the bolts to some 5/16 arp's (drilling out for 3/8 is a bad deal). also spend the 20 bucks on a arp oil pump driveshaft.
other than that i think you'll have a great running motor as long as those heads dont fall apart on ya
my77stang is offline
Old 11-13-2007, 07:42 PM
Starfury
Starfury's Avatar
Contrary to popular belief, 302 cylinders are not actually longer than those in a 289. I knowa couple peoplewho haveactually mic'd them side by side, same length.
That said, if you have a 289 rotating assembly and a 302 block, no reason you can't put the two together (unless it's a one-piece rear main block)
Starfury is offline
Old 11-13-2007, 09:24 PM
my77stang
my77stang's Avatar
o'rly????
289 1 piece FTW? i think yes
Old 11-13-2007, 09:44 PM
SalikDDD
SalikDDD's Avatar
so whats up with the Granada 302 - anything to pump it out to spec?
SalikDDD is offline
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GTJIM
09-23-2015 09:59 AM
ryland
09-13-2015 12:35 PM
Quick Reply: official build up 289
