Wiring Question
Wiring Question
I am wiring a 68 mustang using the painless wiring kit, however I am having a hard time firguring out where this particular item is? Also can you please tell me where the electric choke is for the 954 wiring? Thank you.
Might have to come back witrh further questions, however I am just about done.
Thanks a mil.
Tito
Thanks a mil.
Tito
RE: Wiring Question
Ok, I found 4 original wires coming from the underside of the car. Is that what I am looking for. Also, where is the connection for the electrical choke, oil pressure, and the temperature sending unit?
Thanks a mil
Tito
Thanks a mil
Tito
RE: Wiring Question
the electric choke should be on the carb, the oil pressure sending unit should be on the side of the block near the front and i believe it will be on the right, not 100% sure though
the temp sending unit should be near the thermostat housing
RE: Wiring Question
Thanks, got everything hooked up as far as that. Now, my issue is the fuel sendingwire. I never knew how much fuel I had (I am guessing this is the line that does that) and didn't take anything out. When looking under the fuel tank. There is a cap with a bolt and hose attached next to it and on the passenger side, there appears to be a rubber thing sticking out. Can you tell me where to hook up the wire. Is it the bolt on the cap or the rubber thing on the passenger side.
Thanks a mil.
Tito
Oh and I looking for the back up lights/neutral switch??? Can't seem to locate that one. There are wires in the back that says the same thing and I think I hooked them up correctly, its the engine section part that I am looking for.
Again, thanks amil.
Thanks a mil.
Tito
Again, thanks amil.
RE: Wiring Question
i cant help you with this. but i did have a question. eventually i would like to replace the wiring in my 67. do you recommend the painless wire system for the 67-68, or get the factory replacement ones from mustangsunlimited? any difference between the two kits.
was installing this kit easy so far, was the directions easy to read. so far seems like you are having some trouble with it, and in my head im thinking shouldnt the instructions tell you all this and have pictures where each wire goes.
RE: Wiring Question
ORIGINAL: djsprinklesnjo
All in all, the booklet is good, the wires are tagged, so you know where things go. One thing I do recommend, is know you are car. What it has on it. The kit gives you alot more wires then I needed, and at first I was worried, but after re-thinking and rereading, I was fine.
If you would like, I can scan you some of the instructions from the booklet, so you have atleast an idea of what to expect from the booklet and send it to you.
RE: Wiring Question
ORIGINAL: tdawg_65
Thanks a mil.
Tito
Again, thanks amil.
Thanks a mil.
Tito
Again, thanks amil.
RE: Wiring Question
on my 69 the nuetral safety switch wires ran into the engine bay and straight down to it on my tranny. and my backuplights and whatnot went from inside the interior to the floor shifter. i didnt realize how many things wernt hooked up untill i started taking out wires. none of my guages were hooked up, my electric choke, nuetral safety switch, and several interior items were just cut off and taped
