Headliner Install for fastback... Help!!
Old 12-24-2007, 07:45 PM
az1966
az1966's Avatar
Default RE: Headliner Install for fastback... Help!!
this is why there's forum's,, to ask questions and weigh the options,, glad it all worked out,, as often the case there's more then one way to skin a cat
az1966 is offline
Old 12-25-2007, 10:43 PM
1965forAC
1965forAC's Avatar
Great info in this thread....
Has anyone done this and taken pictures along the way?
1965forAC is offline
Old 12-26-2007, 06:54 AM
john721
john721's Avatar
I didn't take as many pictures as I should have,...I guess "I was caught up in the moment".... I started out by installing the insulation, then I measured the headliner, located and marked the center.I then threaded all bows into the sleeves.The headliner is wider than the bow, so I split the difference and slit the sleeve so the bow would stick out. Next I installed the rear bow.I pulled the bow forward and engaged the 2 wires the set the rear bow position. I checked to be sure the bow was straight. I then pulled the headliner towards the front. I centered the next bow in the sleeve and slit the same as the first bow. I positioned the bow in the holes and rotated it around into position, pulling steady and firm. I repeated this step for the final bow. The next step was to apply weathersrip adhesive to the rear window opening and on the headliner. I streched the headliner just a little and used windlace to hold into place. I went to the front and repeated, only I pulled fairly good on the headliner, and had my son install the windlace pieces. The stretch was good front-to-rear. I then started pulling the sides tight. I needed to cut the sleeves more to get the sides to pull tight. It wasn't difficult at all to access them. After the sides were stretched..it was just a little tinkering with the post section, which will wait until the windshield goes in.. here are a few pics!
john721 is offline
Old 12-26-2007, 07:08 AM
john721
john721's Avatar
The whole job took 3 hours, start to finish...
[IMG]local://upfiles/54210/47824C248C414C94A7B45F15FC62942A.jpg[/IMG]
[IMG]local://upfiles/54210/801D18AB2D764D5B8EAAF9BE2489FD0B.jpg[/IMG]
[IMG]local://upfiles/54210/649F3805C7C24EE388D917ABB9282BED.jpg[/IMG]
[IMG]local://upfiles/54210/F414852E86694FA1B5AF0CEBDDDC6A2F.jpg[/IMG]
john721 is offline
Old 12-26-2007, 07:25 AM
67 evil eleanor
67 evil eleanor's Avatar
Very well done.
67 evil eleanor is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: Headliner Install for fastback... Help!!
