Please critique this overall engine build...
Old 12-29-2007, 03:39 PM
Curse The Sky
Curse The Sky's Avatar
Default Please critique this overall engine build...
The body work on the car is ALMOST done, so it's time to FINALLY start thinking about the engine. For the $2800 I paid, this car has been in excellent shape, and seeing everything coming together is very exciting. Here are my plans for the engine / drivetrain; I'm just looking for suggestions, or anything glaringly obvious where I will be mismatching parts and losing powerband:
-Original 289 (C-code)
-Edelbrock Performer RPM dual plane intake OR RPM air gap
-Holley 4160, 600CFM, electric choke, vacuum secondaries
-AFR 165cc heads (eventually...)
-Not sure what cam yet
-Either 347 stroker or some kind of induction (or both but doubt it), forged internals
-2.5" exhaust, tri-y headers
-4-speed toploader (hopefully)
-9" Posi, 3.55+ gears
It's going to go slow (college student, only making $10 an hour...), but I want to set an overall goal for myself. If I can come out of this making 300-350+ horsepower, I'd be thrilled. Of course, that means disc brakes, etc... but that's another story. The stroker kit, heads, transmission, and differential are going to take the longest to get, so I will be doing this sort of backwards, and there will be a lot of "put it on... take it back off later," but I think it will be worth it.
Curse The Sky is offline
Old 12-29-2007, 04:13 PM
JMD
JMD's Avatar
Default RE: Please critique this overall engine build...
Sounds like a good plan to me. With this setup and a warm cam, I think you will easily meet your goals.
You might consider saving some serious$ by going with a cast steel crank and hyper pistons.
I think that these will be just finefor under500 HP,and nice kits like these can be bought for less than $1,000,,,
Weigh your needs against the costs carefully and your limited $$ will go much further.
JMD is offline
Old 12-29-2007, 09:39 PM
BULLITT GT 390
BULLITT GT 390's Avatar
I'd go with a edelbrock rpmtop end kit thats what I'm going with (soon) its about $2,000 and it makes about 365HP with stock pistons it will save you &(me) money and the holley is a great carb I'm useing a holley 600cfm and its work great! good luck http://store.summitracing.com/partde...p;autoview=sku
BULLITT GT 390 is offline
Old 12-29-2007, 10:01 PM
dcohen
dcohen's Avatar
i was going to go with the AFR 165cc heads on my 289 too but after talking it over with my engine guy he recomended some edelbrock heads. he said that that there wasnt much difference in the 2 and the edelbrock's were a couple hundred $$ cheaper. Basically he said that the AFR heads are great for an all out race engine, but on a street car you probably wouldnt be able to tell the difference
dcohen is offline
Old 12-29-2007, 10:36 PM
JMD
JMD's Avatar
ORIGINAL: dcohen
+1 we are using Victor Jr. heads, they were a little cheaper than the AFRs and they seem to work great.
JMD is offline
Old 12-29-2007, 10:49 PM
67mustang302
67mustang302's Avatar
If you build a 347 you'll want a bigger head than the 165, maybe a 185. Edelbrock also has a newer head out that you'd have to call them about, the Pro Port CNC RPM heads, in 170 or 190 port sizes.
67mustang302 is offline
Old 12-30-2007, 09:47 PM
Curse The Sky
Interesting, I'll do some shopping around.
Thanks for the suggestions, and please keep them coming.
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Please critique this overall engine build...
