Shock Tower reinfocement necessary - 400 HP+
Old 12-30-2007, 06:20 PM
palerider
palerider's Avatar
Default Shock Tower reinfocement necessary - 400 HP+
Recently pulled engine in car to clean engine bay and fix cowl. Don't plan on putting original engine back in but I'm looking at a couple of different crate set ups 400+ HP/Torque. Already beefed rear end and plan on putting disks up front. Also plan on putting in subframe connectors. I'm thinking I should put shock tower reinforcement while I'm at - interested in getting opinions and some suggestions on manufacturers. thanks
Catr is 1970 Fastback. Currently 302
palerider is offline
Old 12-30-2007, 06:36 PM
racin66coupe
racin66coupe's Avatar
Default RE: Shock Tower reinfocement necessary - 400 HP+
how do you reinforce the shock towers?
racin66coupe is offline
Old 12-30-2007, 06:48 PM
baddog671
baddog671's Avatar
Invest in a 1piece export brace and monte carlo bar. Cheap and will keep the front in in place.
Also, for the towers themselves, you can weld up the seams and do a boss brace. Heres a website on those 2
http://home.flash.net/~sanco/mustang.htm
baddog671 is offline
Old 12-30-2007, 09:33 PM
andrewmp6
andrewmp6's Avatar
Theres also http://www.mustangdepot.com/OnLineCa...tower_kits.htm but a export brace and monte carlo bar is all thats needed you may also want to get sub frame conectors too.
andrewmp6 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
10-03-2015 06:23 AM
Quick Reply: Shock Tower reinfocement necessary - 400 HP+
