power steering
power steering
My car does not have powersteerin. I want it. is there anyway i can somehow convert it take a rack n pinion out of a did can and fab it to fit mine or anything also i has the same question on power breaks but minus the rack n pinion part
RE: power steering
My '67 Coupe came with manual drum brakes and manual steering. I found a guy who sells "correct for that year" steering and brakes. No "Granada brake"swap for me. I also found aftermarket steering and brakes that would be an improvement over the factory equipment.
Iconsidered www.steeroids.com for a steering upgrade and www.stainlesssteelbrakes.comfor a brake upgrade.
In the end, price played a role, so I went with www.chockostang.com for my parts. He sold me all original equipment, except for the brake booster (if you use an original booster, you'll have to replace the brake pedal also). I replaced both steering and brakes for $1900.
RE: power steering
well my car is doing the same thing idles really nice but when you put the pressure from the trans rolling on it its not as strong and if you stomp on it it starts to like bubble sound and then if you to push that clutch donw then it shuts off and take a couple mins to get it rollin again. Kinda a (cawicidense)<- spell check that this started after i hack the muffler off my single pipe 67 289cid
RE: power steering
ORIGINAL: JERM_1967stang
RE: power steering
The SSBC brakes are a easy swap, fit good. I bought a original rebuilt psfor my coupe. I am going rack and pinion on myfb.You have to have adual sumpoil pan like on a 5.0.I think there is an issue with the oil pump pickup on 289's.
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
