Electic fuel pump in a 1967 coupe??
RE: Electic fuel pump in a 1967 coupe??
You need a keyed source of power. On our 66 with an aftermarket wiring harness we just hooked up to the terminal that said "fuel pump".
Cant say exactly where the best place to get juice for this on a stock 67.
Back of ignition switch??
On the back of the ignition switch, directly in the middle come out the back, is a threaded stud. This is a switched terminal. Connect it there.
I would buy a fuel pump relay kit (about $24 from Summit Racing)
http://store.summitracing.com/partde...p;autoview=sku
It is a pretty easy install. Also, I'd go to a pick-n-pull and get an inertia switch and wire it in series with the power lead for safety. FWIW, I have a Holley Redpump (no regulator needed for carb) with about 200 miles on it and an unused Ron Morris Performance mounting bracket if you're interested. $85 shipped within continental U.S.
Jeff
Jeff
uberstang1
09-20-2015 06:42 PM
09-16-2015 07:53 PM
