70 Fastback Cowl repair (117 Spot welds)
RE: 70 Fastback Cowl repair (117 Spot welds)
Here is a place where you can buy the lower cowl panel.
http://www.cal-mustang.com/showdetl-7-10704-19-0.html
My son and I just patched everything and fabbed the hat out of a strip of 20 ga. sheetmetal.
[IMG]local://upfiles/61121/23807FCEAA94472DA673A13198CC09BE.jpg[/IMG]
[IMG]local://upfiles/61121/8C2F93515A1B440A827C085C304694B8.jpg[/IMG]
Here is the finished hat......It will NEVER leak after we are done with it.
[IMG]local://upfiles/61121/EE26AEE111B24A8B922081C6DF056D90.jpg[/IMG]
[IMG]local://upfiles/61121/A208EF05924946378CDFA22467B6D50B.jpg[/IMG]
ORIGINAL: 67 evil eleanor
Those are not in too bad of shape. Its good you fixed them right. After the primerI would use a catalized acrylic enamel and weld thru at the seems (3M) overlapping it. I doubt the car will be in the rain ever again but this will protect it if it is. Ford originally did nothing to this area as you now know except the little overspray that made it thru the grills. Welcome to the "Rusty Hat Club".
Reverb, clow is 2 piece upper and lowr. Not including the grill that screws into top.
THey just caem up out with replacement pannel for 69/70 - you can buy upper and lower seperately or buy it prewelded together. CJ, Mustang unlimited both carry now.
ORIGINAL: palerider
Wow - them clows are hard to find
Upper and lower then. I found a piece on ebay that calls itself a Lower Inner Cowl
http://cgi.ebay.com/ebaymotors/MUSTA...QQcmdZViewItem
Any ideas if this is the lower panel?
Okay okay - where is a spell checker when I need one.
Reverb that is the upper cowl you attached. When they first came out Dynacorn labeled them wrong. Attached is the one piece assembly. But again you can buy in 2 pieces. The upper would be what you posted from ebay.
BTW - no misspellings this time.
http://mustang-parts.cjponyparts.com...&view=grid
09-24-2015 09:18 PM
