302 or 289?
RE: 302 or 289?
1st off Welcome to the Forums!The Red hoses are your heater hoses that connect to the heater core!What are the #s on the Block?Let me know and I will tell you what you have!
[IMG]local://upfiles/72436/2687E45583FF40FBB664B730758B43A4.jpg[/IMG]
RE: 302 or 289?
almost the same block. 302 has a longer stroke I do believe. Parts will fit both engines, and if you want to stroke it you can do the same things. what year is the car? Just look behind the starter for the engine blocks #s and get back with us.
RE: 302 or 289?
The blocks themselves are the same, the internals (crank, rods, and pistons) are slightly different. Casting numbers will give a good indication, but depending on the year you might get a 289 with a 302 casting number on the block.
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
