Starting Problem on 1966
Hello Im new here, just bought a 1966 mustang coupe all stock straight 6. My first issue is starting it. It has a new battery, new alternator, and it looks like it has a new solenoid too. Its starts sometime no problem but sometimes it makes a clicking sound or rattling sound on the solenoid and it wont start. I have tested the starter and its fine, I have also done the old trick to test the solenoid by running a screw driver from the power to the first little terminal and all I get is the same clicking noise.
Thanks in advance
David
Thanks in advance
David
RE: Starting Problem on 1966
So I took the ground off of the block looked at it and it looked fine, I also took the ground off of the battery side and then put them back on and she is starteing now. Well thanks for the help torkfastback and I hope that was the problem. I will let yall know.
Thanks
David
Thanks
David
Another trick to check the solonoid is to turn the ignition to the "on" position and then jump the solonoid with a pair of pliers. If when you use the key to try to start the car and all you get is the solonoid clicking, but when you jump the solonoid with a pair of pliers and the starter turns over then you probably have a bad solonoid. (It could also be in the wiring between your ignition switch and the solonoid, but usually its just a bad solonoid).
SO she is doing it again. After I took the ground off of the battery and off of the block and put it back on she started just fine for a day. Took her out again today and she started right up 5 or 6 times then while we where at a park this afternoon with the dog she did it again. Just the clicking noise coming from the solenoid. Luckly we where only about a mile away from home so I just pushed her on home. I have tried the selonoid check with the screw driver trick and I am only getting the same clicking sound. Any more suggestions on this?
Thanks
David
Thanks
David
