found a K code
found a K code
RE: found a K code
ORIGINAL: Scott H.
Well, it appears to have a K-code door (or at least the warranty plate off a K-code car). How many K-codes came with the rocker panel cladding.
Swapped in a 6 banger?
Swapped in an 8 inch rear?
Highly suspect is putting it too softly.
RE: found a K code
It would be interesting to see what suspension the car has. If it still has 5 lug wheels, Kelsy Hayes 4-piston disk brakes, the large front sway bar and stuff then maybe it really is a k code that some idiot ruined.
Also if the VIN numbers stamped into the left and right fender aprons match the door tag...
junior04
09-28-2015 10:53 AM
