Help with my sloppy automatic transmission
I have a 68 6 cylinder automatic. Here's my problem: Park is the only position on my shifter that is accurate. I need to go down past reverse for it to actually go into reverse and the same continues further down.....by the time I get to drive the shifter is all the way down to like where 1st gear would be. Is it worth replacing the shifter bushings or should I look at something else? Thanks.
