Compression Test Question
Well I searched and I think I have the procedure down to perform the compression test, but the only question I still have is whether or not you need to disconnect the fuel line? Any help would be appreciated, thanks!
Thanks! From what I found you run the engine to operating temperature, shut off, disconnect the coil wire, remove all spark plugs, hold the throttle wide open and crank the engine until you get a max pressure. Anything else I'm forgetting?
one lame cylinder is hard to pick out in a v/8, oil test is probably gonna show you a bad valve.
The other cylinders are all around 130-140 psi. Yes, I am using the press in type, I know I know, not the best method, but it's what I've got. When I perform the test on that cylinder there is a definite sound difference. I am afraid it is a bad valve as well.
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
