C4 Pan and Filter Torque?
Hi guys,
I am changing the trans fluid and can't find the torque specs.
Can anyone tell me the torque specs for the transmission filter and pan on a 1966 C4 Automatic?
Thanks in advance,
Jay
Thanks in advance,
Jay
Well the filter came with instructions that said to tighten the pan to no tighter than 12 ft lbs. There was no torque for the filter.
So I will tighten the pan to 10-12 ft lbs. and tighten the filter to 8 -10 ft lbs.
sorry im no help, i just did this the other weekend but my service manual is at my parents house with the car.
if someone has the book they could tell you. i was thinking the pan was something like 20ftlbs but dont trust me on that one
Shop Manual says 12 - 16 ft lbs for the pan. I'm not sure about the filter. Might be the "Screen & Lwr. to Upper Valve Body 40 - 55 Inch lbs". I don't think the filter has to be very tight so 8 - 10 ft lbs would be fine
The bolt torque for the filter was around 40 Inch lbs (I used my calibrated arm to test it). I started to tighten it to 8 ft lbs(with a torque wrench) and realized it was not that tight when I removed it. The bolts are small and when I tightened the filter to 40 Inch lbs it seemed pretty close to the tightness when I removed the bolts.
