reasonings for choosing an alum rad over brass?
well, ive been seeing a bunch of people on here putting alum radiators in their cars instead of brass ones, and im just wondering your reasoning behind this? weight really isnt a huge deal in a street car, and it takes a thicker alum rad to match the cooling that a brass one does.
so do you guys choose the slum rad just for looks? or what? im just curious as to why
A brass radiator may be slightly more efficient in cooling, however it is not as strong. You can take two radiators of the same dimensions, one aluminum and one brass. The brass cooling tubes will be smaller as they don't have the strength of aluminum. Let's say each is three inches thick and the brass radiator is a four row. The aluminum could be a two row, but the tubes in each row could be 1 1/4" wide, giving it almost twice the cooling capacity of the brass radiator.
Brass/copper radiators do conduct heat better than aluminum...but what fakesnakes said is true. Aluminum is stronger and allows for more contact area between the fins and the cooling tubes.
And for some of us, weight is a factor An aluminum radiator might weigh half as much as a brass unit. Combine that with the savings from an aluminum intake, aluminum water pump, aluminum heads, and a battery relocation, and you've got a significant drop in front end weight. This not only lowers overall curb weight, but it improves weight balance as well.
Although the questions have been answered, I don't see any brass aftermarket radiators out there... Not saying there isn't any, but that should be a sign.
Also, all modern cars use aluminum (and plastic) nowadays.
I think it safe to say that aluminum is the way to go.
All radiators for these cars are 'aftermarket.' Brass radiators are available from just about any Mustang shop, as well as your local chain parts stores.
The reason new cars have gone to aluminum/plastic tank radiators is for weight savings. CAFE standards have forced vehicle manufacturers to cut weight wherever they can, and chopping the radiator weight in half is a pretty big deal from an engineering standpoint.
I was referring to companies like BECOOL, GRIFFIN etc... that carry universal sizes.
The brass ones are repros that will bolt right on while retaining the original black paint look
