Bullitts on my 66 coupe??
03-07-2009, 01:59 PM
Interested to know if stock 17x8 Bullitts from a 05-08 Stang will fit on the 66 coupe, do u need spacers and where would I get them from? Anyone have pics of what Im looking at?
Thanks....
03-07-2009, 02:02 PM
ROTM Moderator
You will need spacers. I got mine from ezaccessory.
03-07-2009, 02:09 PM
I've seen this same question 3 times in the past week. I think everyone has said you need 1 1/4" spacers.
03-07-2009, 02:27 PM
Thanks , sent them an email for required application/size....
03-07-2009, 02:28 PM
Would that be 1 1/4 for both front and rear and does it matter if I have stock Drum brakes?
03-07-2009, 02:36 PM
ROTM Moderator
I think it is both. Do you know the backspacing on the bullitts? That will determine the size of spacer.
03-07-2009, 02:57 PM
^^ sure dont, hate to sound $#&%*, but how do I find the backspacing out?
03-07-2009, 03:19 PM
Yukon Cornelius
i believe the 05-08 need a 1 1/2 inch spacer for the fronts. they have a lot more backspacing than the 99-04 bullits
03-07-2009, 03:30 PM
From TireRack
17x8"
Offset: 45mm
Backspacing: 6.32"
Bolt Pattern: 5-114
Rec. Tire Size: 235/55-17
Weight: 21.6lbs.
03-07-2009, 03:32 PM
